ARB TJ Front Stubby Bull Bar Bumper?
Beowulf
Is anyone running the ARB Front Stubby Bumper?
Has anyone fitted a Superwinch 9.0? It says it will not fit, but I'm guessing it is the external brake that is causing issue. Usually it does not fit by just a few 1/16th. A little trimming and it works. But just want to see if anyone has seen this or experience this scenario.
Also, is everyone using the provided shackle mounts or are you doing something different? Maybe something that face mounts to the bumper and can be reinforced with a backer plate? See the bottom pic?
http://www.quadratec.com/products/12000_1001_07.htm
images.ashx
Krytos
I'm running it and I like it.
I have a Warn 9.5ti so I can't help you out with that.
I'm using the stock shackle mounts as they seem to be pretty solid (looking at the pic in the bottom, they are reinforced). I've been winched from them and suffered no ill effects.
Chi-Town
The guy under the car
It doesn't fit the Warn Zenon series either from what I understand. Someone did mention ARB might be considering a design change so you might want to call them.
