I'm placing an ArkPak730 (with a 125AH AGM Batt) in a trailer that is connected electrically to the tow vehicle (2008 Tundra with factory installed tow package) via the 7 pin connector.
So I have wired the trailer so that the Batt terminal of the 7 pin is connected (via 10 gauge wire) in a manner that I can hook up directly to my ArkPak that is in the trailer.
My question is what would be the best way to connect the hot lead from the 7 pin to the ArkPak for the purpose of charging while driving. I am not concerned with charging other than while driving (have solar for that).
Should I connect the battery lead directly to the ArkPak via an Anderson plug?
Or should I connect the battery lead to a cigarette lighter type plug and then plug the ArkPak provided DC to DC cigarette style plug into that plug.
I've tried to contact ArkPak, but they don't answer and have not called back, and their online forum seems to be less than regularly monitored and I need to get on with my installation now.
My concerns are that the cigarette plug option using the DC to DC charger will be a slower charge than going direct via the Anderson plug.
It is my understanding that the factory installed tow package is properly setup to regulate battery charging through the battery lead of the 7 pin connector. I've called my local dealership and they said the same, but one just never knows what advice is good and what's not.
I would appreciate any insight all you fine folks might have with this situation.
Thanks!
Thanks!
