Arkpak portable power and group 31 battery
Azbackcountry21
Located in Chandler Az - no shipping ( due to weight). Local pick up.
225.00
This is an Arkpak portable power station with Group 31 AGM 105 ah.
It’s a 6 stage smart charger with multiple power outlets.
The unit has 2 10amp cigarette outlets. 1 5Volt USB outlet and 150watt inverter along with a 50 amp Anderson plug. Also 2 connections for jump starting another vehicle, running a separate appliance.
In this case you can put whatever battery you want in the unit (lead acid, AGM, Gel). This unit can be charge with 3 sources ( AC house power, DC car and Solar).
They unit is used and functions great, I used it for years to power my portable 12v refrigerator on the road. The unit does have some surface scuffs on the plastic from being moved around. It does not effect the unit which is a hard durable plastic. Included are the AC (wall charger) and DC charger , which I haven’t used.
I will tell you the battery is 6 or so years old and I’ve never depleted it below 50% and it’s been on the 6 stage smart charger since day 1. I am only selling the unit with the battery , which may last 4 more years or 4 months. There is no way to know. Again, you can put whatever battery you want in the unit.
Everything functions as it should and we can test it. This is a great unit to power items on the road, Cellphone, Fans, 12v refrigerator etc.
Also the battery weighs 75 lbs and the ARKPAK weighs about 10 pounds. So it is fairly heavy.
iStan814
