Wanderlusty
About 2 months ago, I noticed pass. rear was covered in fluid. Took it to the dealer and they diagnosed a blown axle seal, which confirmed a suspicion I had. They replaced it, under warranty.
2 weeks ago, I noticed it was leaking again. Took it back to dealer, and they replaced it. Now, LESS THAN A WEEK LATER and...you guessed it...leaking AGAIN!
ARRRGH!!!!
Only 4 days until I depart for the Trophy. And dealing with this again! I researched some on TTORA and it seems that if you have had one axle leak, you have had multiple axle leaks. Possible causes beside just a bad seal are
1) clogged diff breather
2) bent axle shaft
So, i just did the diff breather mod, and it seemed fine, so that leaves either poor workmanship at the dealership or a possible bent axle shaft...
Question is, would they have not checked this? And why does this seem to be such a recurring problem?
I have to admit....I am getting a bit disillusioned. I bought the Taco because it suited my needs, as far as cab config and offroad ability. It serves both purposes admirably, but I also bought it because of the legendary Toyota quality reputation.
Yet, in the 6 months I have owned it, counting taking it BACK in tomorrow, will be the 4th time it has been in the garage for a warranty fix. Once for wheel bearings, and now 3 times for the axle seal. And the truck only has 40K on it.
I have had this truck in the shop more than my last 3 trucks combined.
And now...like I said, 4 days before departing for a 3k+ trip, I am faced with ANOTHER issue.
And so what do I do now? I sure don't want to cancel the trip. In fact, I would rather keep adding fluid if it starts leaking again (assuming they even get it in tomorrow) than have to cancel the trip.
I am just getting frustrated with this issue.
I love the truck itself, other than these issues, but like I said, I am starting to feel a bit disillusioned...well more than a bit....
Anybody else had issues with their axle seals? Any words of advice, encouragement?
ARRRGH!!!!
2) bent axle shaft
