Ashcroft's new Ring and Pinion!!!
Fivespddisco
Supporting Sponsor
Dave has done it again! Ashcroft has created a new product line crucial to the off-roading world. Their new and improved Heavy Duty Ring and Pinion sets are here to make your Rover as strong as it can be! Dave has done this with a number of different design enhancements that he feels surpass that of their competitors.
1) To provide their customers with a vast variety, there are now five different ratios to select from (3.50, 3.75, 4.12, 4.37, and 4.75)
2) All Ring and Pinion now have both normal rear directional and newly added reverse cut, the front axle may now drive on the stronger side of the gear to provide maximum strength.
3) A lower count was needed to increase the strength so Eight teeth have been used in different configurations. The result is wider tooth that allows better absorption of shock loading on your vehicle.
4) For your convenience, Ashcroft also offers easier fittings. All pinions accept the standard 24 spline flanges and have the female threads compatible for bolts. 5) The new heavy-duty ring and pinion sets are also constructed out of lab tested genuine materials. This was done due to disappointment in quality of previous materials and to increase durability.
6) To further increase the life span of your parts and create a unique appearance, Ashcroft has coated these ring and pinion sets in Chemical Black, preventing corrosion and provide more resistance.
7) The highlight though, of the new product's strengths is its Helix angle. This is the increased angle of the teeth's "scroll," resulting in more contact area. With a larger contact area, pressure is displaced and the ring and pinion can withhold a greater amount of weight and wear-and-tear.
8) All for only $328 per diff!!!!!
As always Lucky 8 strives be your first choice in Land Rover drive train. We are constantly searching to present you with the latest and greatest parts from across the world, and it looks like Ashcroft has pulled through yet again!
4Rescue
WOW... You'd think that with all the time that Rovers have been around, someone would have already done this...Great work and excelent design ideas for making a crucial drivetrain part even stronger. And the price is amazing IMO when compared with say a set of good Yukons or the like...very competetive eh, espescialy for what you're gettting.
Keep up the good work mate, and any chance there's a future for Toyota variants??? I know how you Rover guys like tyo borrow our 3rds ;) so maybe we can all benefit from this eh...
Cheers
DAve
Fivespddisco
Supporting Sponsor
Cheers
DAve
Thank you for the kink words I will make sure dave see this
Clemtiger84
