AT Fast Disconnect Shower
WMac
Ask Martyn from AT. He is one of the niceset folks here, and will be happy to assist you getting it to work on your trailer.
Martyn
Jason, I don't have all the information you requested. It's a little complicated, we can no longer buy the fittings direct from the manufacturer and now have to buy them through a distributor in Europe. Unfortunately this change means we can no longer get the fitting with American pipe thread connections any more, and have had to switch to a Marine fitting called a Whale fitting.
We have the shower mixers in stock and are now sourcing all of the Whale fittings that will attach to the back. Until we have the all the parts we won't know what the depth of the mixer and fittings are.
All I have as far as pictures of the back of the fitting is one of the old style mixers. We are hoping the new set up will have the same overall length or less.
The hose is .75 meters long.
gabepari
I have some with the Whale fittings at the shop. I also have the Whale 15mm to 1/2" NPT adapters. They do add some length, but not a whole lot. I will measure them in the morning and post up.
Gabe
Martyn
Gabe
Gabe, I believe we are going with a push to connect fitting, or a 90'
racingjason
Thanks so much Martyn, the picture gives me a good idea of what the unit looks (will look) like. Please let me know when the fittings get sorted out and we can go from there. One last thing, could I trouble you for the length and width of the front plate of the unit? (I am looking to cover an existing hole in my trailer.)
Cheers.
Clemtiger84
