AT Horizon Trailer for sale with pics.
Bellpilot
Hello All:
AT Trailer-Horizon model built in December 2009 for sale. price: No longer for sale.
Specs: Horizon Trailer-OD Tan Color with black Chassis.
1) nose box-power coated
2) Fuel can set-two with AT trailer Holders
3) Water Tank-19 gallon roto mold with 1.25" opening, 1/2" drain plug with pump.
4) 12v power-Aux 12v power lighting w/night light, ARB Adventure light, with THREE fused outlets, batttery tray and hold down.
5) 31D- TWO: Valvle regulated AGM Group 31 deep cycle battery 105 AMP.
6) RV-20- Carmanah RV-25 AMP Solar panel Charge Controller and surface mount.
7) TWO Powerfilm Solar Foldable Solar Chargers, 60 watts (3.6 amps @15.4 volts). Very expensive.
8) Daisy chain Accessory to connect two powerfilm panels in to increase current.
9) 15 ft. extension cord.
10) Weather pack connector kit
11) Power tender Dual: Noco marine series On board Amp (10/10) dual battery charger & maintainer shore plug.
12)Electric braked Axle upgrade with 10" drums, includes break away kit.
13) Max Coupler-multi-axis coupler, 3500 lb. Class 2.
14) Horizon kitchen- slide out 2 burner stove, cutting board, compartment dividers, 11 lb. propane cylinder and bracket (two propane tanks).
15) 6x6 F-35 Awning and telescoping brackets.
16) Eezi-Awn series 3, 1800 roof top tent 70"x 96" (very large)
17) Engel 45 liter fridge/freezer
18) Insulating transit bag for Engle fridge
19) slide for Engle fridge
20) Jeep Rubicon rims
21) pro Comp 35" AT Extreme" tires
22) Stainless steel sink with mounts.
23) Maxxima 6x1 watt LED haevy duty work light
24) marine outlet- 12volt marine grade power outlet, locking type.
25) ARB 12 volt DC 13 watt work light.
26) Manchester 11 pound propane cylinder & bracket-TWO
27) COLOR- custom powder coat OD Tan.
Thank you,
Randy
Bellpilot
Keeping the AT Trailer after all....
Hello All,
Well after careful reflection, I've decided to withdraw the sale of the AT trailer. So much went into the planning, preparation and execution that it would be almost a crime to sell it. Adventure Trailer is a dream company to work with and the two principals, Mario and Martin, define the definition of "professional". It also looks like my overland vehicle project will most likely not become a reality. The logistics were becoming problematic.
Thank you, all, for your interest and see you all on the road less traveled.
Best regards,
Randy aka Bellpilot
flipstick
