J_L
I decided to go with the integrated solution for my Yaesu FT-857. The ATAS-120 was pretty easy to install and works well for it's size. On 40 meters I made contacts easily during the day with 50 watts. If I could hear them I could work them.
I chose a front mounting point. The antenna is tuned to 7.245 Mhz so it's about as tall as it gets.
A Diamond K400 holds it firmly to the hood.
3/4" tinned braid grounds the antenna.
A common point for grounding was available behind the battery, the negative lead connects to the body on it's way to terminating on the engine block.
Overall I'm very pleased with this solution. It's the quietest mobile setup I've ever run, a pretty low profile compared to other screwdrivers and the radio controling the antenna via the coax is a real plus. Not having 80 meters is a minus but generating an rf wave that is 240 feet long is a tough proposition for all but the largest mobile antennas.
