Allen Bosely
I need some input and suggestion as to what and why on axels,diffs & lockers.
I'm somewhat on the fence between a SIII 109 or an 83' 110 as my expedition rig to rebuild. At this point leaning towards the 110 for the sake of simplicity in the rebuild.
So, for an 83' 110 that will have these basic modifications/upgrades:
Tdi 300, R380, LT230TC, new chassis and probably bulkhead, rear discs. On 255/85 16 tires.
It will be an expedition vehicle as opposed a hard core off roader, so it will be loaded somewhat heavily and pulling a small expedition trailer.
It will be taken to Southern Africa. So I don't want to modify the front and rear ends any more than necessary. As in putting in 1.5" axels that require machining the housings and hubs and such. If it breaks I would like as much as possible to be able to use stock LR parts salvaged some where to limp home.
Thinking of something along the lines of these choices:
Peg the Diff for cheap insurance.
Great Basin Rovers 24 spline Heavy Duty axels front and rear, 4.10 ratio gears, Detroit locker in Rear,and Tru-track in Front. Simple, no air lines.
Or the above with ARB locker Front and Rear.
Or a Salisbury Front with the ARB or Tru-track.
Salisbury's can be found in the UK (with a bit of hunting) I've seen a couple for sale.
I am trying not to modify it to much as in the Toyota Diffs and axles and such, for ability to fix it in the Boonies. If it was only going to be in the US that might be a way to go.
What combination would you recommend based on the type of vehicle and use and why
Allen
Allen
