Mitsubishi seemed to glue theirs on, I have also found them to have a large O-ring on many occasions seemingly installed by Mitsubishi although I have never found a part number for it.
...and MR241229 is the part number for front the hub shim kit, these go under the CV snap ring often times after installing new hubs you need to reshim the outer joint. Usually they're close enough though.
I've also had good luck in that application with Yamabond 4. It's semi-drying and stays the slightest bit flexible. Thinner than RTV so goes on OK. I am told Harley guys often use that to re-seal split crankcases, which are notorious leakers.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
