Axle hubs to fit jeep wheels for trailer build
wADVr
Pretty sure most all aftermarket wheels that are NOT hub centric will fit. Otherwise get some spacers, seems what most people do for running factory take off wheels.
Semi-Hex
Enfant Terrible
It seems to be the trend to use spacers on almost all the builds now. I wanted my lugs to be metrics's is my 4Runner, so I have spacers though my hub hole is big.
captwoody
You have to run spacers or non hub centric wheels, I added a 3500 lb axle to my little harbor freight adventure trailer so I could run 5x5 hubs to match my jk. Ordered axle 3" short to make up for spacer width. Added lighter springs tows like a dream now
full
rlgrace2011
I just ran into the same problem with my trailer build. I wanted to put my 2015 JKU rims on the trailer to match the jeep. I purchased the Dexter 3500# idler axles with a 5x5. I got around the hub not fitting by getting a set of 2 inch LUG centric spacers off amazon. It worked perfect. Hope that helps!
travelall74
