Axle legnth for a 416?
doc holiday
Can anyone tell me what legnth of axle i should order for my 416? I am going to change it out to match my bolt pattern on my Toyota, and i would like the upgrade in genral. Thanks in advance.
shogun
Or would i be better to just get a couple of wheel adaptors? The stock pattern is 5 on 5.5 right?
A rough, eyeball, measurement shows 57".
Given workable offset/backspacing, I would use adapters. Easy, strong, cheap, and reversable. Calculate the width by keeping the tire in the stock position.
I use wheeladapter.com
adventurebuddies
Hi. I'm gettng ready to buy a new wider axle and will order with the Toyota pattern. So I will need to sell the adapters that I currently have which I think are the exact bolt pattern adapters you are looking for. They have only seen one trip of a few hundred miles and I'll sell them for half price. Pm if you're interested.
KE5QVT
M416 - 58 3/4 from drum face to face. 2.28" tube diameter, 1.59" spindle diameter. 5 on 5.5 bolt pattern, 16x4.5" rims
M416A1 - 61.62" from drum face to face. 2.28" tube diameter, 1.06" inner spindle diameter, 1.38 outer diameter. 5 on 5.5 bolt pattern, 16x4.5" rims
I just got finished rebuilding my M416 so I have all of this, plus I changed my axle to an electric brake 6 on 5.5 to fit my toyota rims. the cost was the same as just buying some replacement drums to make the 5on5.5 to 6on 5.5 swap.
http://www.expeditionportal.com/forum/showthread.php?t=42558&highlight=m416+build+started
flipstick
