"Backpack"
Ryan87LX
Here it is - new to me trailer.
Very lightweight homebuilt that should suit my purposes perfectly. Will fit a top to it, add some matching wheels and tires, and create some kind of camp kitchen or table for use in camp. There will not be a RTT, but I will haul my big Cabella's tent in it.
Ryan87LX
A few updates:
1. As some who is new to the world of trailers, I've learned a lot. First, and perhaps most importantly, the trailer sitting in this position (see above) as it's natural resting state is not good. I added a storage rack in front of the box to shift some weight onto the tongue, and had the tongue extended a bit. A big improvement in balance and towing. It used to get squirrely above 80 km/h, now it seems smooth up to 100.
2. I don't know how to use a measuring tape. When I bought it, one of the selling features was that the axle had the right (5 x 4.5") bolt circle for matching Explorer rims and tires. It turns out it is actually 5 x 4.75. Oops. In my defense, I knew that the tweaking the tape measure to go around the hub would change the reading, I just misjudged how much. Apparently my 'eyecrometer' is only accurate to .250 of an inch. (I also learned that they make a tool to measure the bolt circle of a trailer. So I'm not the first to make this mistake.) On top of that, it also turns out that this is some kind of weird home made axle with 1950s Chevy front hubs as axle hubs. I tried to service one and found parts hard to find and very expensive. A new axle is set to be here tomorrow. Hopefully I measured the spring mounting pads properly!
3. I finally got to work on the lid. I'm replacing the lip you see on the picture above with one that is beefier, and then adding a hinged top to it. In a way, I suppose I'm trying to emulate the look of an M416.
I'm taking it on a 600km one night camping trip this coming weekend. It won't be completely ready, but it will be a good opportunity to see how things work as designed and an opportunity to work out some kinks before the whole family uses it for a week at a time.
tgreening
If you're taking the trailer as it is in the last picture be careful making your turns. There doesn't seem to be much tongue length in front of your rack and it looks like it might hit in a tight turn.
Ryan87LX
Thanks! There is an extension that goes on the front of the tongue that provides lots of clearance though. I've been towing it around town and the extra weight and length really balance the trailer out nicely.
AZXPLOR
