Hi,
Tearing apart my Bantam T3C trailer, and having one problem. The through bolt in the coupler will not budge. The one the goes through the chain brackets, coupler, tongue rails, and landing leg bracket. I believe it is 3/4x16. I had to cut the nut off, and have sprayed pb on it for over a week. I have beat on it with a hammer, used an impact, cheater bar, and drilled the bolt all the way through. Will not budge. The pieces around it move, so I have a hard time believing it is still rusted on.
Is it pinned in from the top? When I look through the hole i drilled I can see what looks to be a pin dead center, and it has spot directly on top of this area that looks to be welded. Any thoughts?
Thanks.
Thanks.
