Base Camp Aquacube Portable Shower
jwrare
I won this shower in a raffle (OX East if you were there) - AWESOME. Planned to use with offroad trailer I'd been eyeing but the winds have changed and will be heading in the direction of a more indoor solution.
I was able to demo the Aquacube and was very impressed! Easy to adjust temp and regulate water flow.
$300, OBO
Here's more info:
BaseCamp Aquacube Instant Hot Water or Portable Shower is the most advanced hot water generator in the world being both digital and cordless.
This 180,00 BTU liquid propane hot water generator raises source water temperature up to 45 degrees F and is the most advanced in the world today. This great new product is both digital and cordless, allowing you to enjoy a hot shower even in the most remote places. The internal battery will power through 8 five minute showers and the unit can be hooked up to AC or DC power as well with included cables. A 1 lb disposable cylinder connects directly to the included pre-calibrated regulator to deliver over 60 minutes of hot water on high. The included pump delivers .8 gallons per minute, ensuring that your shower is as good when roughing it as it is at home. Integrated safety features, like the over temp cut-off and flow detector, allow you to turn the burner on and off from the shower head and protects you from scalding water. Monitor the water output temperature and the battery level from the water resistant, digital display and transport your unit with the included carry bag.
  • 18,000 BTU per hour
  • Flow rate - .66 - 1.18 gallons per minute
  • For use with propane gas
  • Water can be increased by up to 45 degrees F above source water temperature
  • Built in rechargeable battery powers LCD display and pump for 40 minutes of run time
  • Complete kit includes - shower head and pump assembly, AC and DC adaptors, and carry bag
  • Dual outlets - adjustable on and off shower and tap outlets
Bart Miller
I also won one of the three that were given away. The showers definitely keepper in my book.Nothing like a hot shower after a long dusty road.
1reddog48
