Basic rules of 2M communication for newb's like me...
DaveInDenver
Middle Income Semi-Redneck
asteffes said:
It drives me nuts when people use Q-codes on 2m/440 repeaters.
I agree, at least to some extent. On a repeater there is no reason not to be clear with your language. Q codes are meant to keep CW contacts as brief and sustinct as possible (since 3 characters are far easier to pound out rather than whole phrase) and aren't really meant for use on voice contacts.
k6uk
I actually like the Q codes, personally.
I find them easier than 10-codes, and they instantly convey the info.
But to each his/her own.
73 (oops there I go again),
-Mike
DaveInDenver
-Mike
73 is not actually a code anymore, just tradition. Supposedly goes back to the Western Union telegraph days, when they had a whole number code to convey information. I believe it simply meant (and certain does now) 'Best Wishes' or something similiar.
Since they were also using Morse Code, this is very similar to Q codes. Now 10 codes, don't get me started. I, like most 4 wheelers started (and still use for off highway travel) a CB. It does bother me when ham users start talking 10 codes and Roger, Roger. The whole point of using FM is that you get a clearer conversation, you can just talk like normal.
asteffes
How about weenies who say "roger" or "over" on a CB, FRS or amateur repeaters with a "roger beep?" Now *that* is rediculous.
DaveInDenver
On CB, I figure if the contact is marginal, using 'roger' or 'over' is fair (heck, any sign of courtesy by a CB operator is OK by me). I'm with ya on the roger beep! :)
vanguard
I just talk like a normal person but don't get bothered by any use of q codes or 10 codes. I know what they mean. Half the time I'm out in the woods I'm straining to understand Boomhauer southern accents so a 10 code now and then is a welcome relief. :)
If I ask a simple question don't reply with craziness about hen's teeth. It's hard enough to talk on the radio already without insane non sequiturs working their way in. :D
crawler#976
Does ExPo have a set of frequencies used?
I've got these input into memory from 4WDTrips:
4WD 1 146.430
4WD 2 146.460
4WD 3 146.490
4WD 4 146.580
4WD 5 147.420
4WD 6 147.450
4WD 7 147.480
4WD 8 147.540
4WD 9 147.570
DaveInDenver
crawler#976 said:
4WD 1 146.430
4WD 2 146.460
4WD 3 146.490
4WD 4 146.580
4WD 5 147.420
4WD 6 147.450
4WD 7 147.480
4WD 8 147.540
4WD 9 147.570
I've got them programmed in, but it seems prudent to mention that these simplex frequencies are based on 15KHz channel spacing, which isn't compatible with all band plans. Some local plans use 20KHz spacing, like most of Utah I know is on 20KHz spacing. When in areas that use the wider spacing, be mindful and follow their rules. On 145.510-145.790 use odd 20 KHz and 146.420-146.600 and 147.400-147.600 use even 20 KHz. So we'd only use 2, 4, 5, 7 & 8 in Utah (and I think Oregon and a lot of the SE states, like GA, etc.).
