Battery Bulkhead Connectors?
jsmoriss
Hi everyone,
I'm going to run some #2 wire from my starter battery through the firewall. Instead of using grommets, I'll be using some bulkheads for a cleaner and easier install. Some of the issues that I have to think about is resistance and isolation / protection. I definitely don't want to short the positive bulkhead sometime in the future! :) I've been thinking of ordering these:
http://www.tunerschoice.com/xq/aspx/paging.yes/dept_id.248/display_id.220/add.true/qx/Product.htm
Does anyone have a better idea? I'd probably paint (enamel) and silicone the crap out of them. The wiring will be fused at both ends anyway, so in case of a short, one or both fuses will pop.
Thanks,
js.
ntsqd
Heretic Car Camper
More of the first option:
http://store.summitracing.com/egnsearch.asp?N=700+115+-123432&D=-123432
I've also seen the QD's typically used on welder's for the leads used for battery cable disconnects at a bulkhead, but that doesn't sound quite like what you're looking to do.
Antichrist
jsmoriss said:
I spent quite some time searching for 'firewall bulkheads' but really I should have been searching for 'battery bulkhead connectors'. There's a subtle difference -- this last one will bring up marine-type connectors! :-D So, I found this one, which looks a lot better:
http://www.vteworld.com/content/electromech/bhc/html/bulkhead_connector.php
js.
If you have the space. They require a 2.75" diameter hole.
I like the first ones you found, that's what I use. They only require a 1 17/64" hole. They are also available with red or black insulation.
If anyone uses those, I suggest using the Tweco brand, they are more commonly available in the US, in my experience. Any welding supply shop carries them, and I think ACE Hardware carries Tweco, though not as broad a range. Mostly just the male and female cable ends are available at ACE.
dhuss
