That One Guy
This is taken from Sure Power's website.
4. Start Signal input
This is the input for engine start signal override. When power is applied to this input, the relay will close if the Aux. Battery is no less than 0.85 Volts below the Main battery.
The manual says to use a momentary switch, but it seems smarter to use a continuous switch(or whatever the normal ones are called). Maybe I'm missing the point of what this feature is for. Can anyone explain?
