Bed liner on the old Military trailer
wvtradbow
I just finished lining my 63 m101-A1 ,turned out Okay. I used Liner Xtreeme on the inside,I used this before on a truck bed and iy holds up really good,However it is "xtreemely" messy to use,i'll explain later.
wvtradbow
This product is actually a 4 part mixture in addition to the gallon of product you have reducer,activator and a baggie full crushed rubber to add which gives it a rough texture,you don't have room in the gallon to mix so I used a 5 gallon bucket with a paddle stir on a drill then the gun fits the reducer can but I had to cut the gun tube to fit an finally poured back into the quart reducer can which is difficult because this stuff is really thick an sticky. I bought 2 gallons of this about 3yrs ago used 1 gallon for a truck bed an was worried about the shelf life in an unheated garage for the rest,BUT it was was like I just bought it.
wvtradbow
thought I'd do something a little different,as you can see the parts store ran out of 1s so I improvised
wvtradbow
I really like this Liner Xtreem cause it covers a lot of bad body work on this 54 yr old trailer but I'm not sure you can paint over it so I used Dove grey Raptor liner for the body.my take on this so far because I never used it before is: It's very nice to work with, a 3 part mixture if you add the color additive but not near as thick as the xtreem,my only complaint about it is,although they leave enough room in the quart container for the activator there isn't enough room for the color addititve so I had to mix it in a different container an all you do is shake this product,plus since I had to cut the tube on my spray gun for the extreme,the raptor you can screw the gun on it an its a taller container so I had to buy another gun for it but that was only about $15.
BUGOUT2
I Raptor lined my interior too
lkretvix
