Vegard_S
I'm looking for some new shoes for my Unimog, It's a 1980 U1700L with Om352, 168HP, standard gearing, 8-bolt axles.
It currently sits on Pirelli road tires 13.00 R22.5, on 9x22.5 rims. I want simmilar or bigger diameter on the wheels as the current ones, so that the RPM's on the engine can be lowered when the truck is crusing. Now It cruses at 80km/h at aprox. 2500rpm.
![20180609_122348.jpg 20180609_122348.jpg](https://expeditionportal.com/forum/data/attachments/369/369244-729ac095b473bd67c9c5d33ba5d092df.jpg)
I am considering Michelin XZL in the following sizes:
- 13.00 R22.5, diameter=1130mm, (possible to re-use old rims, + same size as used on many older European trucks and trailers)
- 395/85 R20, diameter=1189mm, (Larger tires, seems to be used on a lot of unimog campers, need to buy new rims)
- 14.00 R20, diameter=1258mm, (Even larger tires that will lower RPM on engine dramaticly at crusing speed, cheap 2.hand tires available from various suppliers, but maybe to big, will they require a cabin lift?, also I would have to buy new 11x20 rims)
I'm also considering various rim options. Prefferably OEM Mercedes solid rims or split rims. If I go for the split rims simmilar to these:
http://www.unimogs.co.uk/our-stock/spares/wheel-rims/set-of-4-8-bolt-20-rims-wh0082
- Will I then have to also instal inner hoses in the tires?
I'll be gratefull for any inputt on the subject!
