hour
Anyone ever used one of these BT BMS units? A lot of them seem like junk visually and are often for more than 4S batteries, but I've seen a couple.
I write mobile apps (iOS and Android) for a living, mostly Bluetooth LE stuff at this point including firmware for microcontrollers so apps can talk to them.
It would be extremely easy to assemble an ESP32 powered unit that operates a relay directly tied to your charging input for about $8, knowing when to operate the relay based on individual cell voltages pulled over bluetooth from the BT BMS. This could be configured wirelessly from a simple app. Also ten cents to add temperature monitoring and also use that to disable the charge input if too cold
All the photos for the BT BMS units show a crap-app to accompany it, almost always in Chinese. What are the odds of their BT being accessible by third parties - anyone investigated yet? There's a couple many-thousand dollar bluetooth sniffers at work but I'm not familiar with them. Could get a coworker to help me out but best would be someone responding "Yes, I've researched this, and X company has a github"
I'd build the unit and have it directly capable of reading cell voltages - just mount in the battery box - but I'm less confident on hardware assembly and the few projects I've found on the internet are over my head. Also no clue if one could tap in to a cheap exposed board BMS and read voltages from certain solder points with a microcontroller.
Thoughts, knowledge, experience?
