BMW G650GS Nearly new 2011 Best Dual-Sport Warranty Extras
scritch
Perfect condition
~1,900 miles
Warranty! Fully transferable 3-year warranty from BMW!!!
I absolutely adore this bike. I'm selling it because I'll be moving out of the country in a few months and the cost to ship it plus the import taxes are higher than buying a new bike.
Includes Givi tail rack and compatible case ($200). Holds 2 helmets or tons of gear.
1st service ($200) completed. Next tune up not needed until 6,000 miles.
Tires and brakes are in great condition.
Everything is dialed in and the bike is running great.
70mpg!!!
ABS (can be turned off for dirt riding)
Heated grips
Lowered suspension upgrade (fully adjustable front and rear)
Makes the bike manageable by those with shorter legs or people like me that want the extra control from being able to stand over the bike.
Center stand
The bike is in near new condition. There are only a few nicks and scratches here and there. The worst scratch is on the tip of the handlebar, shown in its own photo.
You can read a full review with detailed specs, photos and analysis: http://www.webbikeworld.com/BMW-motorcycles/bmw-g-650-gs/
Here are some abbreviated specs:
Year 2011
Manufacturer BMW
Model G650GS
Engine Type Single-cylinder four-stroke engine
Displacement 652cc
Bore & Stroke 100 mm x 83 mm
Compression 11.5:1
Cooling Liquid-Cooled
Fuel System NA
Ignition Electronic
Starting System Electric
Transmission Synchromesh five-speed gearbox built into crankcase
Final Drive Continuous O ring chain with shock damping in the rear wheel hub
Rake and Trail 61.9° / 4.5 inches
Wheel Base 58.2 in.
Seat Height 29.5 in.
Front Suspension Telescopic forks with fork brace
Rear Suspension Boxed dual swing arm of steel sections, central spring strut actuation lever system
Front Brake Hydraulically actuated single disc brake, 11.8 inch floating two-caliper brake
Rear Brake Hydraulically actuated single disc brake, 9.5 inch floating single-caliper brake
Front Tire 110/80 R19
Rear Tire 140/80 R17
Fuel Capacity 3.7 gal.
Dry Weight 423 lbs. (Wet)
KBB value: $7,495 (Plus the lowered option, plus the warranty, plus the rear case, plus recent tune-up)
This bike has more power, better gas mileage, better reliability and more features than the comparable bikes from Kawasaki, Suzuki, Yamaha and Honda. The longer service intervals and higher gas mileage will over time bring the cost of ownership below the bikes that featured an initially lower price. It is a truly great bike.
scritch
SOLD: 2011 g650gs
Perfect condition
~1,900 miles
70mpg!!!
Heated grips
Center stand
Year 2011
Manufacturer BMW
Model G650GS
Displacement 652cc
Compression 11.5:1
Fuel System NA
Ignition Electronic
Wheel Base 58.2 in.
SOLD!
iStan814
