Build recommendations for new gen1 tundra owner
donrafa7
Donrafa from SoCal and recently picked up 00 Tundra 4x4. Not new to turning wrenches but new to off-road.
A little info on the truck:
00 Tundra 4x4 AC TRD 164k miles- Had ball joint failure
within last 1k miles:
New oil/filter air filter
Steering rack and axles
New OEM LCA
Lower Ball joints
SPC UCA
Bilstein 5100 all 4 corners, 2.5" perch on front
Brakes and rotors (NAPA)
Tune up
Tires wrangler AT Kevlar 265-70-16 - probably should have gone more aggressive but for $400 installed (craigslist special) and needed tires badly I bit
I am new to off-road and plan on doing light off-road/camping
Winch/Recovery:
Maxtrax
Recovery straps (tree saver, snatch blocks, D rings, recovery strap)
Shovel, First aid and Trauma kit, Fuel and Water tanks
Front mount hitch and smitty xrc 9.5 synthetic (~375-450)
Air- I only have ~31" tires so i'm thinking C02/power tank system will suffice for my needs
Lift wise- I don't want to lift it any further, maybe just an add a leaf or firestone airbags for any additional loads.
Tire Wise - If I can get some extra scratch and find a good deal maybe upgrade to some cooper STT pro in a 265 75 16 size, BFH if needed on pinch welds
Armor- I don't plan on adding armor/sliders/bumpers, maybe a skid plate if there are any very vulnerable spots on these trucks, I don't care about scratches/dings as this was an actual work truck in its previous life
Lighting- what's do you recommend for additional lighting, I really hate giant light bars that scream "BRO pass me the Vape"
Sleeping- I grew up sleeping on the floor so pitching a tent and sleeping on a sleep pad is what I'm going with (if my wife decides to come along i'll have to turn this into a 4 star hotel)
Drivetrain- Leaving it Stock
I'd like to upgrade the essentials and just get out there, I don't want to be building this thing up for years and dropping $$$ just to do some mild off-roading (I'm notorious for doing that with my sports cars, build build build, race a few times, sell). I think that my plan will suffice for getting on fire roads/mild off-road/ desert trips/maybe a Baja trip but I'm a noob so what do I know. Shoot me some recommendations/criticisms on my planned setup.
JLee
Unless you're going far out by yourself and/or have a habit of getting in sticky situations, I wouldn't worry too much about a winch. I played around in the desert in AZ and in Baja for years without ever coming close to needing a winch. I also don't tend to push vehicles hard. Air is a great idea (airing down is one of the best 'upgrades' you can do offroad), as is a patch kit (and knowing how to use it).
Really if you just want to 'get out there', a good set of all terrains and a stock truck will take you many, many places. :)
Check out squashingrocks.com for what I've done with my trucks - sounds really similar to what you want to do.
AaronK
It's pretty solid as it sits. Just start using it and change things as you find things you don't like
Sent from my OnePlus One using Tapatalk.
marathonracer
At that mileage/age you will want to do a timing belt change if it hasn't been done yet. The 2uz is an interference engine so a belt failure is a big deal.
donrafa7
A timing belt is in the near future, as well as diffs and transfer fluid
SPC looks to be way beefier than oem and the camber/caster adjustment is now super easy to do myself. A suggestion to anyone installing them freeze the bushing that gets pressed into the the knuckle, makes a 30 minute press job take 1 solid hammer blow to install. Also like that they are greasable. Install was only a few hours for both sides.
iStan814
