Well, I don't know about the rear fog lights. I'll be replacing the rear bumper with a steel one, and I'm not sure I'd bother with them. As it is, I have to figure out if I'll need to put reverse lights into the bumper, since that's where they are now, or if I can get away with using the work lights as reverse lights? I'm not sure of the exact legal requirement for reverse lights, the work lights will be quite high.
The reason I can't just wire the work lights through the rear fog light circuit, is because it is a momentary button which sends a signal to the body control unit, which then turns the lights on. It will not turn the lights on unless the truck is running. But, I want to be able to use the worklights with the truck off.
That is why I need to rewire with a new relay system anyway.
At this point, I just want to be able to turn the lights on and off whether the engine is running or not, with a push of this button, which is a momentary button. Thus the need for a latching relay.
I'm less concerned about the lights coming on with the reverse lights. I think I'd rather just to that manually as required.
NTSQD, cool, thanks. I'm hoping to pull if off without hard to find devices, but I'll use that if I can't figure another way.
