Hopefully we will be buying a pickup early in the spring. Its main use will be for camping. I am currently working on an old boat trailer that will be used to haul most of our camping gear, but doesn't really offer anyway to secure the coolers from the bears. I thought about a regular pickup cap and fiberglass tonneau cover which should do the trick but the are expensive unless you can find a cheap used one, and I want something I can pull off easily. So I got to thinking what if I put stakes in the the beds stake pockets and run a 2x6 length ways down the sides of the bed and then bold an angle iron on the 2x6 and slide 2x10s across the bed. It wouldn't be water tight but doesn't need to be. The bear probably could climb on it and not fall through (not real big bears) and I could remove easily. With out doing the math yet it should be fairly inexpensive to build as well. Any insight would be appreciated.
Thanks Todd
Thanks Todd
