ClangClang
Long time lurker here. I've been slowly biding my time, following all the build threads with a mixture of envy and longing. I'm about to ready to jump in though and could use a quick sanity check.
A friend of a friend is selling his 2001 F150. Super Crew. 4x4. 5.4L V8. Pretty good shape overall, some dings and dents here and there. Drivers seat has a big tear. Otherwise seems to be OK from a quick glance. In the past 18 months, the truck has:
- New-ish tires (about 10k miles on them)
- New Spark Plugs
- New Coil Packs
- New radiator
- New thermostat
- New belts and hoses
- New water pump
- Block flush, removed freeze plugs, replaced with new ones
- New Front End Alignment
- New ball joints
- New shocks
- New battery
- Upgraded Bluetooth Stereo, door speakers, Rockford Fosgate Amp with Kicker 10’s
- New Brake Calipers Front and back
- New Brake Pads front and back
- New Parking Brake Shoe
- Brake fluid flush
- Tinted windows
- New axle seals
- New Door Lock Actuator
- New Multi-Function Switch
- New Pitman Arm
- New Cruise Control Switch
I am about to buy a fixer-upper house with the wife. The plan for the truck is to spend the first ~8 months using it as a work truck to shuttle supplies back and forth as we finish the reno on the house, then start building out the truck after. Intended use for the truck: Overlanding in North America, no extreme off roading, no rock climbing. Lots of 2-4 day camping trips, often accessed by Forest Service roads. Accessing backcountry skiing and ice climbing in the winter - fairly remote objectives, often in very bad weather. Regardless, it will still be on road 95% of the future miles.
So if anyone has some wisdom to share, I could use some help with the following:
Much appreciated!
- New Spark Plugs
- New Coil Packs
- New radiator
- New thermostat
- New water pump
- New ball joints
- New shocks
- New battery
- Brake fluid flush
- Tinted windows
- New axle seals
- New Pitman Arm
- Decent price?
- Is a truck with 250k on it just going to be a money pit going forward?
- Anything specific with this year/model/drivetrain I need to pay special attention to?
- Anything else you can think of!
Much appreciated!
