SlimPickins
Escapee
Amature doing timing belt on my 1998 Montero 3.5L SOHC and per research done on this site, I'm also doing water pump, cam seals, crank bolt, tensioner, pulleys, etc. I lined everything up to TDC before removing timing belt. I then rented a tool from local autoparts store that is supposed to hold the cam gear in place while I use a breaker bar to loosen the nut so that I may get to the front cam seals. Well as I was bracing the passenger side gear with the tool and pulling counterclockwise (its a standard bolt I hope..) on my breaker bar to loosen nut, the cheapo (plastic) tool slipped off the cam gear and I ended up turning the whole thing counterclockwise several degrees. I obviously had the timing belt off and the spark plugs are still in so it kind of jerked counterclockwise several degrees.. I carefully turned it back clockwise to roughly where the timing marks were before performing this stunt but my valve covers are off so its hard to tell if it is perfectly aligned with the marks.. Did I bend or screw anything up?? If the cam turns a bit when doing the timing belt job, can you simply turn them back and align before replacing belt? I assume turning the cam through an entire rotation is a BAD idea but a few degrees one way or another to realign ok?? Hoping for some good news and better advice on getting this cam gear held in place while I try to loosen nut! Thanks in advance for your help and patience! I'll post up my pics of the job as soon as I can.
