Camburg UCA's for '02 Tundra?
Flyer69
I'm about to dive into a front end rebuild, including new LCA's, TC spindle gussets, tie rod ends, swaybar end links and lower BJ's. Any suggestions on where can I find the best deal on a new set of Camburg UCA's for my '02 Tundra?
Also, since I'm at 187k miles, I am considering replacing the front wheel bearings while I have it all torn down. Good idea or no? If I did, I'd remove the hubs myself and take the spindles to a shop (or dealer) with a big press and have them R&R the bearings.
As always, thanks!
pirates712
I just replaced the steering knuckles on my '00 Tundra with used parts because the bearings were bad at 167k miles. I had zero play, the passenger's side sounded dry and the driver's side would seize up after sitting for a few days. That said, if your bearings aren't showing any of those symptoms I would rather tear it back down in the future than replace now.
Flyer69
Thanks for the info guys. I looked at Icon's website, and it doesn't look like they make UCA's for my '02 Tundra, just '07 and up. I'll check out SDHQ.
