Camp Northern Lights - Minden, Ontario, Canada
AlekG
Camp Northern Lights 2008 - Minden, Ontario, Canada
Part I
So this year I actually did a bit of advance planning and was able to go to Carlisle AND the annual off-roading weekend (Aug 15-17), called Camp Northern Lights, about 2 hours north of Toronto.
Not without my share of headaches though. CampNL has three full days (Fri - Sun) of trail rides so my plan was to either go up Thursday night or very early Friday. Everything was going great Thursday as I picked up the Trailblazer from National4WD and getting the 4.56 gears and electronic locker installed.
Knowing that the speedo would be WAY off, I brought along my laptop and the HPTuners program. And then like a rank noob, I decided to try to reprogram it in the parking lot of a nearby Canadian Tire. Of course the absolute worst thing that could happen, happened. I scrambled the computer (or so I thought).
Lucky I subscribe to OnStar so I got a free flatbed tow (GM roadside assistance) to a dealership close by my home to the get the computer re-flashed (as I had the original PCMforLess tune on my laptop). Well the bad news came on Friday around 11 AM. The computer was not just scrambled, it was was fried. They wanted $900 for a new one. I told them to go **** themselves and got towed back home.
I then got on the line with PCMforLess and they very graciously helped out by sending me a replacement computer with my original tune PLUS the gear ratio change for $99 + overnight shipping to Canada with Saturday delivery.
So on Saturday the replacement went in, I went through the security procedure, and I headed off to CampNL in Minden. I arrived just in time for the last dinner scraps and the for the weekend awards and prize giveaways. I then quickly set up my Tent-Cot and dozed off.
The next morning my friend Mike came up. He was going to ride shotgun and take some action photos and video. All the pictures are actually frame grabs from the HDV video we shot on Sunday on the Concession Lake trail. Check out his photography site at MikePhoto.com.
6:00 AM at CampNL headquarters
Driving through Kinmount on the way to the trail
Airing down with the Mil-Spec deflators
AlekG
Part II
The summer around here has been uncharacteristically wet so we were warned that the Concession Lake trail would have its share of deep water crossings and mud. The trail was rated a 2-2.5 out of 4 which was the easiest of the bunch. However, after completing it (not without incident BTW), I would have to comment that this type of trail is not really for the lone traveler. A passenger (or second vehicle) for spotting duty is a must I believe. We had 9 vehicles and 3 guides which by the end of the day, came in very handy.
Here's a cross-section of trail conditions and obstacle types to give you an idea of the environment.
Oh, and nobody worry ... that tree was already felled when we got to it. It was just a little to low for my roof rack so we had to prop it up as I drove under it.
AlekG
Part III
Here's an obstacle where all the parts of the Trailblazer worked very well together -- 4WD, LO range in the transfer case (2.7:1), 4.56 gearing, Auburn Ected electronic locker.
This was the deepest water crossing I did that day, although there was another deeper one later. In the middle picture you can see that the water was to the top of my tires so that would make it 32 - 34 inches deep. No problems with the air intake although the filter did get some splashes on it during the day, I can see the mud stains.
A couple of miscellaneous shots of the Trailblazer.
AlekG
Part IV
This was the most difficult obstacle of the day. Everyone got spotted through it very slowly. They call it the "teeter-totter" because if you position yourself just right, you can balance on 2 tires - front left and rear right. I have to mention here that the Mickey Thompson Baja MTZs are an awesome tire. They got me through everything that day, I think I only felt slippage once.
Some time after the teeter-totter we heard over the CB: "Trailblazer - find some level dry ground ASAP and stop". What happened was that the rear Hotchkis anti-sway bar sheared either from hitting something or just from the stress of articulation (I didn't disconnect). So out came the grinder and it was cut off at the ends, leaving the 2 JKS disconnects connected. It was easier this way than to try and take the bushings out on the trail.
Just so you know, I wasn't the only casualty that day. We had a broken radiator mount from the deep water, an overheated engine, and 2 completely flat tires (on the same vehicle) right on the teeter-totter from slipping the beads (he was running 15 psi)
At the end of the day we came to the final water crossing. This one is notoriously deep and long but has a bypass, which I took. The bypass is on the right in the picture. Three vehicles tried the deep water with varying degrees of success ... but no one got stuck.
Overall a great experience, mainly because of the people and how well the Trailblazer handled itself. The guides were absolutely great as well as everybody else as we all pitched in and made the necessary trail repairs to keep us going.
Although this is not my primary mission, as I prefer "expedition-type" outings where the goal is a destination or point of interest (that's why I like the Peter Massey books so much), I would definitely do it again next year to gain further experience in driving over obstacles and adverse conditions.
The other part of the equation is the camaraderie present and the people you meet. I can't tell you how many good comments I got on the Trailblazer as the off-roaders I met were genuinely pleased to see people working on "non-standard" vehicles.
4307
Looks like you guys had a blast at NL's this year. :safari-rig:
Great pics! It was the kick in the *** I need. I'll be there next year.
Was the event a sellout this year?
AlekG
CampNL 2008 - Video
OK, I finally got Final Cut Studio back up and running earlier this year and have edited down the hours of video into shots related to my Trailblazer.
This was all hand-held so pardon the shakiness. The video was captured by my friend Mike Lascut. His photography/videography website is www.mikephoto.com.
The video is just under 10 minutes.
Here are the High Def versions:
File Size: 398 MB
Resolution: 1280 x 720
Video codec: H.264
Audio codec: AAC
Duration: 9:54
File Size: 210 MB
Resolution: 852 x 480
Video codec: H.264
Audio codec: AAC
Duration: 9:54
View the system recommendations for the best playback experience.
