Camprite trailer
gowalkabout
I'm only new here but thought I would show you all our Camprite camper trailer. They are built here in Australia and built tough with heavy duty independent suspension and the ability to sleep 6 in beds all up off the ground. which is great and means we can set up on rocky, muddy and wet areas if needed without any problems at all. there is a great kitchen attached to the tailgate and we run LED strip lighting (I'm about to re do the lighting atm). it all packs down to a good size when closed. has 2 water tanks holding 65L each which are connected to a 12v pump. it also has 2 annexes, a small one and a larger one with walls for when setting up for an extended period. Here's a link to the camprite site http://www.campritecampers.com.au/ and a couple of photos of mine
gowalkabout
Here are some photos and some links to some of our travels
Our blog (not updated nearly enough) http://walkabouttravels.wordpress.com/
and our Facebook page https://www.facebook.com/gowalkabout
So each side has a single bed with a bunk over it and it is a large double bed that pushes over the front of the trailer. leaving a good size area with bench seating in the middle. Although not in these photos we do also have a thermal blanket that goes over the main tent that is great in the cold to keep the tent warm and also in the hot to keep the heat out. it is made from what looks like large bubble wrap with a silver coating
Goldenbora
