I have been working to install an Icon 3" shackle and hanger kit on my 2002 F450. (For those that are wondering, this kit does fit, even though Icon does not advertise as such for 450's and 550's.) The kit is only to lift the front.
Anyway, I have the driver's side buttoned up. One the passenger side I have the new spring hanger mounted with the spring in it. The rear of the front passenger spring is giving me the trouble. I have the new shackle mounted to the frame, but the trouble is that the rear of the spring is too inboard to fit into the shackle.
I think I got luck on the driver's side and it probably helped the passenger side was loose when I was doing the driver side.
The axle u-bolts are loosened.
I think that some combination of the letting one side droop or jacking another side must get it to line up, but I am not figuring it out.
I also have used a little bottle jack on top of the spring, pushing off the bottom of the frame, to coax things up/down, but I need side/side.
If I disconnect the track bar would that help? I have a new one anyways.
I also thought about getting a High-Lift and using at a spreader (base on the drivers frame rail, running horizontally over to the spring and pushing it outboard.
Any advice would be great, I included a few pictures, not sure if they will help or not. Thanks
