Greatwhitetaco
Up for sale is my 2020 overland trailer build. It is a 6x12 insulated trailer with rear loading ramp and rv side door with deadbolt. This trailer is extremely light weighing around 2000lb. This has been used on 3 trips with no issues. It has 31” nitto terra grapplers to handle any and all trails. There is a roof rack across the top with easy load bar for kayaks. Rear loading ramp has been Bedlined and has built in stands to turn ramp into a small patio. Inside is a full size Murphy bed attached to E-track. Folding night stand/table. Grey man tactical Molle gear mounts. RGB led lighting with remote. A kitchen module with sink and 5 gallon fresh and 5 gallon grey. Running water. 1500 watt pure sine wave inverter with optima yellow top deep cycle battery. 60w solar panel with solar controller. 3 outlets and 2 USB ports for powering all your gear. Epoxy flooring throughout. Easy load RV entrance step. Kitchen and bed can be easily removed if you ever need to tow larger toys. And has multiple floor plan mounting options via the E-track.This trailer is capable of going anywhere your vehicle can and take all your other toys with you. need to sell for unexpected bills. $9,800 OBO located in ABQ, NM
