Cargopro 6x12 all aluminum RV build $5,950
richwolf
2021 6x12 Custom converted aluminum Cargopro Stealth cargo trailer.
$5,950
Weight of trailer before conversion was only 955 pounds.
Insulated walls and ceiling.
Walls painted and cedar ceiling and cedar trim.
Linoleum flooring.
Wrap around counter with room for stove and food prep.
Built in stainless steel sink with water pump and foot control for ease of use and to save water with 5 gallon water container.
Full size thick memory foam mattress.
Bed can be kept made at all times.
Full length fold down shelf next to bed,
Two side windows with screens.
Magnetic screens on front and back doors.
Solar system consists of a 1 kilowatt hour lithium battery, variable voltage charge controller, Victron 500 watt inverter plus power strip and a 100 watt flexible solar panel.
Front door and the two back doors have heavy duty door latches to keep them stable.
Remote control roof vent with variable speed fan and in or out fan flow.
Linear actuators under each leg of the bed allows you to raise the bed up 18 inches to give more storage. We would put up to 3 bicycles there for storage or travel. Two remotes for the actuators. Pictures show bed in lowest position.
Flip up counter next to main counter is where we put our cooler.
We used an old cooler at the foot of our bed for our pantry and as a bed step.
Two door cabinet above the kitchen counter and numerous wire baskets to hold things and numerous hooks to hang things.
Includes two new windows that you can install yourself in the locations you prefer.
Two step block included for getting in and out of the trailer plus a fold away grab handle.
4 pin trailer wire hookup and Led lights and running lights.
Light enough to tow with most vehicles.
Probably less than 3,000 miles total. Tires are in excellent condition and the spare has never been used.
Most of our use was in Borrego where we left it for the winter in a camp spot.
A perfect bug out camper with a solid build and off road capable.
We have a free and clear title.
Thanks for looking!
richwolf
Pictures:
Todtan
A few questions for you:
1. Can you add pics of the battery and wiring
2. Can you add pics of the water system under the sink
3. What is the max height of the space under the bead when its at it's highest?
Thanks!
richwolf
1. Attached are pics of the electrical system.
52 volt lithium 1000 watt hour bike battery charged from a solar panel through a charge controller. Battery is wired into a 500 watt 48 volt Victron inverter. Power strip is plugged into the inverter. A 12 volt dc converter plugged into the power strip which gives power to the water pump, fan and linear actuators. A simple system with no hidden wires. We also used a Pecron solar generator (not included) with another solar panel to power our heated mattress pad which kept us toasty warm at night.
2. Under sink water system picture attached. Sureflow pump takes water from the 5 gallon container and foot valve delivers it to the faucet. Great hands free system that saves on water. Water from sink drains out the bottom and is caught in a container.
3. Bed at lowest level is 24.5 inches and the actuators raise it up another 18 inches giving a clearance to the bottom framing member of 42.5 inches. The height under the bed is about 3.5 inches greater if you factor out the 2x4 inch bed exterior frame support.
guapstyle
