Silver dude
Xplorer
I had a 15" cobra magnetic mount wire whip antenna on my last expedition trip to Michigan.
However, after consistent whacks with tree limbs it snapped the whip right at the set screw mount and I was left with no antenna. Not wanting to go down the same road again what are my options?
Here are my requirements...
Quickly removable or fold able setup, I only use the CB on off roading trips and need to fit in a low garage every night. The Mag mount was perfect for me as I simply unscrewed the antenna from the mount and stored it in the seat pocket.
Must get good range, I'm aiming for at least 5-10 miles once tuned. My wire whip left some to be desired.
Survive tree beatings.
After viewing others setups I'm considering a hood mounted 2' or 3' Firestik with return spring. The only thing I don't like about that setup however is that its going to be constantly in my vision. But, I'm imagining that mounting near the hood would be better as it allows for greater flexibility and a lower profile away from trees.
Otherwise, I'm thinking a 2' firestik mounted to the roof rack with a really flexible spring mount. I would actually prefer it as it would be a less noticeable setup and wouldn't have a ugly hood bracket when tooling around town.
Are Firestiks easily removable? I see the coupler setups which are really nice however stacking them with a spring mount as well would make for a silly long mount.
I'm open to other antenna suggestions as well.
