CDN M101 Bushings
New Horizons Overland
NEWHORIZONSOVERLAND
Anybody ever replaced the main eye bushings on their CDN M101? These are for the spring mounts on the trailer frame. If you have can you tell me what you used and maybe a part number if you have it. Thanks!!
NEWHORIZONSOVERLAND
Just an update for anyone needing to replace theses in the future. The part you are looking for is a Dayton RB-1. I checked them with a micrometer and they are an exact match to the original. I just installed two on my trailer and the work fine. Just be sure they are Perfectly straight when you start pulling them in or you are in for a major headache. Good luck.
VanIsle_Greg
Good info...mine are original and I am going to be refurbing the suspension soon so this is good to know. Thanks for sharing!
Greg
NEWHORIZONSOVERLAND
No Problem. One tip....take some 220 or finer grit sandpaper and smooth out the bushing and the inside of the hanger tube. Then take a brass wire wheel and polish it up. when you grease them both it goes in relatively pain free.
iStan814
