Change of plans
96discoXD
Well, I had begun building up a 1990 GMC Sierra for some overland/light expedition use, but I quickly came to the conclusion that simply wasn't the ideal platform.
Therefore I am picking up a very nice 1994 YJ in a couple days. The downside is it's a 2.5 liter stick, but I plan to do a V8 conversion in a couple years.
For now I'm going to install TJ flares, do 1" shackles and put some 31-inch tires on it. I will also be adding a winch, rear receiver hitch or bumper, hopefully with a swing-out tire carrier, possibly an ARB snorkel and some other things.
I plan on bedlining the entire floorpan to prevent future rust so I can just pull the carpet when offroading and leave it in when on road.
I'll also be pulling the rear seat and building a cargo platform with rear drawers and upper storage compartments that will allow me to place more storage on top.
Long term plans call for an expo build on a 1967 M101 military trailer I have sans bed.
96discoXD
Weekend update:
Picked the jeep up on Saturday and drove it home. All is good but reverse on the AX5 is already acting up. I may just pick up another one locally.
I did score a hardtop and doors over the weekend locally for $100 and have already repainted the top black. I'm still debating whether to keep the hard doors and paint them or sell them to fund my build.
I also have a set of custom bumpers being build, the front has a winch mount and fairlead mounts built in with some upper protection bars in sort of a prerunner configuration. It also has 3/4" plate welded in for D-rings and a couple light mount tabs being added. It will be bedlined and hopefully I can pick it up this coming weekend.
The rear is similar style with a 2" receiver built in and will have 3/4" plate for D-rings to be installed for an additional recovery point. I'll probably add a swing out tire carrier some time down the road, but I decided not to for now for budget reasons. I already ordered a Smittybilt XRC-8 winch for the front, based on feedback from people I've talked to it's slow, but reliable for a budget priced winch.
I'm rethinking the lift shackles now that I've decided to replace shocks, I may just do a 2.5" OME lift and the TJ flares. I'm leaning toward a set of five 31x10.50R15 BFG Mud Terrain KM2's for tires, but still up in the air.
I'll start taking pics so I can do a build thread for anyone interested in following it.:coffeedrink:
JeepN95YJ
I used to run 31s on stock wheels with a 1 inch body lift on my YJ. Used it offroad a lot and it worked great. You probably won't need any lift at all if you are using TJ flares.
I'm sure you will be happy with an OME lift though.
(post pics!)
96discoXD
My original plans were to do the flares and just 1" shackles, but my shocks need to be replaced and I'm finding myself falling prey to the "while you're in there" mentality. I know the springs are originals and I'm going to be putting heavy bumpers and a winch and hauling a lot of gear on trips so I'm thinking the lift springs would be some insurance against losing some clearance when loaded up. I've used OME products in the past and they're fantastic. I figure if I go with the HD 2.5" lift springs I should have no problems even when loaded down with gear for hunting or a week long expedition.
If I were just going to run a few trails and not load it down too much I think you are right on the money.
jeepdreamer
Go diesel...
Since the engine swap is still a ways away I'd suggest going diesel! My 91 YJ will get this eventually...I dig it and they are some smart folks. Sorry if the clip/past of the email they sent me doesn't show the pics...try their web page for details.
You really need to determine which rear axle you have in your YJ. If its the 8 1/4 then you should be fines even w/32s. If you got stuck with the dana35...plan on swapping that. They like to break sitting alone in the parking lot at night! ;)
HPA Jeep TDI Project August 16, 2010
Thank you for subscribing to our Jeep newsletter... Though we are old veterans when it comes to motor swaps and crazy vehicle conversions, the Jeep scene is somewhat of a new one for us and we appreciate your support.
While the step by step build process will be covered by JP magazine, we wanted to offer our loyal readers some insight into the direction this project has taken behind the scenes.
Initial study and conversion:
We started with a 1991 Jeep Wrangler YJ with the 2.5L 4cylinder and AX-5 gearbox as there seems to be no economical rebuild path for the aging power train on this very common package. The (PD) TDI engine we selected weighs in 55lbs lighter than the original 2.5L AMG motor we yanked out, and produces 45 lb-ft more torque that our Jeep would have done in its prime.
With the engine removed, the OEM frame mounts have been detached and our new mounting solution is bolted in. You can choose to either weld or bolt on our mounts, but our test mule will have these bolted on so we can stress test them long term.
We retained all original Jeep geometry from the flywheel back through a crank shaft adapter and bell housing adapter assembly. The OEM Jeep flywheel is modified to match the crank shaft adapter bolt circles allowing you to uses any off the shelf Jeep clutch kit. We have had many satisfied years of working with SPEC for all our high performance Volkswagen/Audi builds and as such have chosen their Stage 3 clutch kit for our Jeep project.
The engine has now been in and out of the Jeep a number of times as we documented and patterned the widgets that have gone into this initial build. It is very exciting to see the cleanly installed assembly as it looks like it could have come that way from the factory.
Our TDI is rated for 100hp and 180 lb-ft of torque stock in its stock form but has even more potential with a few simple performance mods. Because our conversion retains the original engine ECU, a power prom flash can easily be added to bump this to 165hp and 280 lb-ft of torque respectively.
Adding to this package, we have designed our downpipe to mate up with an off the shelf Magnaflow 2.5" exhaust system for the Wrangler. As it happens, 2.5" is the ideal diameter for maximizing the power of the TDI.
We are also exploring a custom cam for our PD motor that will smooth out its idle and adds a proven 12hp gain and 22 lb-ft of torque as a stand alone upgrade (outside any power flash).
Our team is only weeks away from unveiling the finished project, complete with some new goodies for the body and chassis, and we will have pricing available after the Labor Day long weekend.
We will be offering three groupings:
Grouping 1 is a bare bones package targeting the Do-It-Yourselfer. It will include everything required to take a late model TDI motor and physically integrate it with the 4cyl YJ driveline. Our team will supply a list of TDI engine codes that are best suited for this conversion.
As pictured:
- engine mounts
- bell-housing adaptor
- crankshaft adaptor
- Machined flywheel (exchange)
- Downpipe
Grouping 2 will include everything in Grouping 1 and will expand it with our custom air intake solution and an air to water cooling package, along with the coolant line flanges we have designed to retain the OEM Volkswagen cooling system.
Grouping 3 This package will be a little ways off but will include an entire engine assembly with the majority of the electronics prepared for installation; including radiator fan assemblies, etc.
For all three groupings, we will offer an "Immobilizer Defeat" service to those wishing to utilize the original VW wiring harness and ECU as we have done in our project. This will open the door to a variety of TDI power prom upgrades and retains access to factory VW OBD diagnostics.
Once the demo truck has been shot by JP magazine, we will bring in an AX-15 gearbox and start at the adaptor system for it, along with pulling in a 6 cylinder Jeep to verify that our current mount solution will cross over with no issues.
As always, we welcome your feedback... please email us your questions or comments.
Sincerely,
The Team at HPA Motorsports
sales@hpamotorsport.com
604.598.8520
96discoXD
Diesel is a nice idea, but the reality is that the small block will be a very straight forward package to install and parts are going to be available pretty much anywhere in North America. I'm not as concerned with mileage as I am with reliability and ease of service. I don't know enough about TDI's to be able to service one on the side of the road or on the trail, I can handle a SBC with my eyes closed.
The only time I have ever really wanted to do diesel was when I had my 1996 Disco XD, I wanted to put a 300tdi drivetrain from across the pond in that thing so bad it hurt!:drool:
Warhead
I would keep the hard doors unless you really need funds. I have had seven jeeps over the years, the glass windows that you can roll down are almost worth their weight in gold compared to the canvas windows in soft doors. just my .02 YMMV
96discoXD
smbisig, that's a great looking wrangler you have! I hope some day mine will be able to be built to that standard.
Thanks for the input on the doors guys, I have all but decided to keep them at this point. They will need a little work but I'm thinking that during a downpour or even just during cold weather use or hunting it will be nice to have the hard doors. I don't intend to drive the jeep much at all in the winter so it isn't exposed to any more road salt just to keep the body and frame as nice as they are.
I am hoping to pick up my bumpers this coming weekend and if I have time I am going to mount the hardtop, put on the bumpers, and the winch this weekend along with a few other bits and pieces as time allows.
Clemtiger84
