Does anyone know how to go about this I want to change the lug patern on my trailer from 5 to 6so that it matches my truck. But I don't know how to tell if I am able to or not any help is very appreciated
If you have a trailer shop, or Boat us, etc... you can pull one of the spindles, bring it to the local shop, or Boat US, and they should be able to match you up with a set of 6x5.5 to match your Taco.....
ok cool thanks for the help thats what i was wondering i really hope they can cuase i have old wheels that i pulled off my truck that would match it for the trailer and help it sit higher. anything i need to watch out for when pulling the spindle off
If you note the bearing numbers and call some trailer axle suppliers (Dexter Axle, ABC Trailer Parts, Franklin Trailers, etc.) they may be able to sell you "loaded hubs" with new bearings, seals, retainers, etc. and send them to your door.
Before you get too far into this, make sure the rims you want to use don't have so much backspacing that the tires rub the trailer. Compare the wheel mating surface-to-trailer body distance against the tires and rims you want to use and allow about two inches of clearance. You may want to upgrade your axle now to achieve this.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
