Check these out!
revor
Stackable Fuel and Water Tanks!
Turn that Daily Driver into an extended range Expedition Master..
Nate13
What brand are these?
I have actually been in the market for some jerry cans...but these seem interesting enough to check into.
Do you have a website to buy them from?
DaveM
Those look just like these tanks I've seen that are intended to be used as water catchment tanks under decks and houses. Roof drain plug into tank, tanks are sized to fit between joists and can be hooked together in series. Made in OZ I think.
revor
I waiting on my friend to send some info up. Expected details by now. The coolthing is that you can stack them and that they make the same tank for water so that can stack right there as well (put a water tank on top of the gasoline tanks for that automatic fire extinguisher effect :) )
I doubt they will be "cheap" but might be a nice investment if they are built well.. Compared to the $1055 I was quoted for a built in water tank for my deefer even $500 sounds pretty good.
As soon as I here something I will post it up.
R_Lefebvre
Just switch to diesel. You know you wanna!
You're right, I do, but $$$.
I waiting on my friend to send some info up. Expected details by now. The coolthing is that you can stack them and that they make the same tank for water so that can stack right there as well (put a water tank on top of the gasoline tanks for that automatic fire extinguisher effect )
Yeah, except for water will just spread a gasoline fire.
Houie
