Another hit-n-run post...
Some of this will be repetitive to our past discussions...
- Put a roll hoop inside the vehicle behind the rear bench (C-pillar). Make sure occupant heads can't hit this hoop in a whiplash situation. Consider adding rear head rests.
- Put a halo on the outside that attaches through the roof and goes forward to the A-pillar area.
- Run A-pillar supports down the A-pillars on the exterior, through the top of the fender; somehow weld/bolt to the front bulkhead and/or front unirail. I can't visual the structure there right now for some reason - try to incorporate some kind of a "butterfly" stiffening assembly in this area similar to what is used on a race prepped Miata or S2000.
- Also add a hoop at the D-pillar, complete the roof structure support at this area.
- I'm not a fan of the D110 style external cage. I understand why it is done that way but I see it as something to get snagged on trees. I'm also more for clean visual design. The D110 setup looks like a kludge caused by safety regulation changes as far as I'm concerned. I'll let a LR zealot correct me.
- It wouldn't hurt to use those clamps in the B-pillar area. I don't have much faith in the gutters though. The drip rail is just a pressed on thing where the side and roof panels are welded together. Or you could do internal down tubes inside the body. Given a choice between the two I'd lean to the former. Internal tubes anywhere near a skull with no helmet are a bad idea IMO.
- I wouldn't stress too much about lateral triangulation in the interior roll hoops. The practicality of this structure will not allow good triangulation anyway. You can't triangulate the windshield area obviously.
- The purpose of this structure is to help in addition to the existing unibody sheet metal. I'd hazard a guess this would be at least twice as strong as the existing roof. Probably more.
- I need to think about this more, but my inclination would be to have the C-pillar hoop leaned backward at a say 70* angle, the D-pillar forward the say angle so they meet to make a triangle in the side view. Close the triangle with some horizontal tube at the bottom. Additionally brace laterally through the area under the floor and/or under the bench to stiffen the base points. Attach the roof structure at the top. Massively strong over the little ones in the rear bench.
I dunno. Shoot these free formed ideas down.
