Hard to tell what brand from that photo, but there were dozens and dozens of RV manufacturers in that era that made similar units. It's just a Class-C RV, nothing atypical. They are everywhere in the states.
The chassis was supplied by GM. The body/coach would have been built by a coach manufacturer. There should be a serial number plate inside on the wall or door jamb area that says who built the coach.
Whatever the body is, it sure is a clean machine on the outside! No idea on the body manufacturer either but the chassis is definitely a 71-77 G30. 1978 received a much different grill. Most G30's had 350 small blocks but the 400 small block was an option for a few of those years. Both were backed by a TH400 transmission in the G30.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
