WhereTheHellIsJames?
Here's what I'm trying to do...
There is a running light on the front of my motorcycle, that is normally on constant. What I would like to do, is to get it to blink with (or opposite of) my turn signals when they're engaged. The running light power must remain constant, and the light should remain on, unless power from the turn signal circuit is applied, in which case, the light should extinguish.
In the picture below, assume that the square is what I need (two wires going in, one coming out- power to one wire and the circuit is closed, power to both wires, and the circuit is open), that the wire from the left is from the turn signal circuit, and the wire from the right is the running light circuit...
Here's a link to a YouTube video of what I'm looking to do...
There's no explanation of what was done, but my goal is similar to what the bike in the video does.
This is 12VDC, and is a relatively small bulb (like a motorcycle turn signal bulb). Dual filament is out of the question due to mounting option restraints. I'm open to any ideas, but if there is a way to do this solid state instead a mechanical apparatus, then that would be the best option. FWIW, I'm handy with a soldering iron
Thanks in advance!!
Thanks in advance!!
