**************' CJ RockCrawler. Trailready. Street-legal.
merk1000
California Trip April '07 082.jpgThis probably sounds too good to be true, but true it is: :Wow1:
https://plus.google.com/photos/118379956219812241207/albums/5940301325974537201
$13,000
1983 Jeep CJ-7 that is California SMOG legal with Board of Air Resources (BAR) sticker. Never wrecked or rolled, only mildly four-wheeled locally. Runs great, drives great. 1999 4.0L w/MPI, AW4, Dana 300 w/clocked 4:1, Tera 60 axles (high pinion, high clearance Dana 60s), ARBs front and rear, 58:1 crawl ratio, engine-driven air, 9500# winch, toolboxes. Many spare parts, 3 tops, heavy duty cargo rack, tow bar. This Jeep is one of the most capable, street-legal CJ rock-crawlers around. It'll also do 70 mph on the freeway, comfortably, all day.
24k miles on engine/transmission
20k miles on axles, transfer case
142k miles on frame/body
ENGINE and DRIVETRAIN
1999 Jeep Cherokee 4.0, MPI fuel injection
AW-4 transmission with external transmission cooler/Flex-a-lite electric fan
Dana 300 transfer case rebuilt with 4:1 gears, twin-shifters, clocking ring
Tom Wood's custom driveshafts, front and rear
High-pinion, high-clearance Tera 60 axles, 5.13 gears, front and rear
ARB air lockers, front and rear
Four-wheel disk brakes with hydroboost power brake system, stainless steel lines
Manu-matic electronic transmission controller (manual or automatic shifting)
Hesco air intake
Four-core radiator with Flex-a-lite dual electric fan
Dual Interstate battery system with isolator
Kilby engine-driven air compressor, 2.5 gallon external tank, dash-mounted gauges
24-gallon Trailquest heavy -duty fuel tank
Custom aluminized exhaust
SUSPENSION, STEERING, and WHEELS
Rancho 2.5" Wagoneer springs, spring-over-axle
Wheelbase lengthened 3" and widened 2"
Shackle reversal with Boomerang shackle kit, greaseable shackles
Adjustable helper springs in rear
Rancho 9000 adjustable shocks, front and rear
High-clearance, heavy-duty custom steering
Currie anti-rock sway bar
AGR power steering box with adjustable turning ratio
37" Wrangler MTRs (50%), 24-bolt Champion beadlocks, Eagle 15x10 aluminum wheels
Centramatic automatic wheel balancers
Full-size, matching spare
FRAME and BODY
Boxed frame with built in custom front bumper with built-in fog lights
Tow bar system
Boxed rear frame with custom rear bumper/rock guards
Six-point REMOVEABLE roll cage with racing padding
Four-point custom nerf-bar/rock sliders
Custom spare tire carrier with hi-lift jack and gas can mounts
Full-coverage custom crossmember/skidplate
Custom hitch
Body and frame coated with POR-15 and Rhino lining, inside and out
Exterior body painted semi-flat black with DuPont IMRON aircraft primer/paint
INTERIOR
MasterCraft Rock-crawler suspension seats
Rhino-lined, sound-proofed, rubber floor interior
Tuffy console with CD player, 2-4" and 2-6x9" speakers
Tuffy sliding drawer toolchest in back mounted above the floor
Rear-view infrared color camera with screen built into rear-view mirror
Heavy-duty heater core and high-speed fan
Original Cherokee AW4 shifter with custom mount
Custom manumatic shifter controls
Twin transfer case shifters
Lokar emergency brake
EXTRA!!!!!!
Warn 9.5TI winch
Congo-cage body mounted rack with KargoMaster rack
Surfboard racks, snowboard/ski racks
Ravelco Anti-theft device
Stainless steel brackets and hardware
Full set of shop manuals, user manuals, receipts, rebuild log/pictures/diagrams
Full set of tools and spare parts (lines, pumps, fluids, etc.)
Dark-gray, original hard top and doors, black Bestop softop/doors, black bikini top
Semi-flat black, IMRON aircraft primer/paint
Air-conditioning system included, not fully connected
60" high-lift jack
Pull-pal winch anchor
Jeep Cherokee gauge cluster
Extra-dash plate
dhuss
