CO2 Tank Date Stamps
millerfish
Can someone please clarify this test date. Is this the due date or the last test date? When will it need testing again?
v_man
it means it was tested on 02/14 , so it should be 'good' for five years after that ...
FWIW , I've had filled , and returned empty Co2 bottle that were well past the five year date stamp , if the shop doesn't bring it up , neither do I .
LR Max
Local Oaf
I recently got hit for it. It was due the month before. He let it slide but he said next time I'd have to get a new tank.
Hate to let go of my fancy orange tank.
doug720
Just have tour tank re-certified the same as any other compressed gas tank - SCUBA, welding gas, etc.
Here in SoCal it costs around $35-45.00 and takes about a week for the turnaround. Any place that fills the tank will offer this service or know where to send you.
After a successful test, the tank is restamped and it's good for another 5 years.
v_man
you probably already know this but if you're carrying that tank in your rig for off road use and tire fill up , try to get an aluminum tank . I carried an old steel tank around , and my whole kit (tank , regulator , lines , gauges etc. ) was probably 80 pounds. Then I got an aluminum one , muuuch lighter .
Also , make sure you secure and strap the heck out of it if it's riding inside the cab with you ....
Johnrunberg
I use these tanks for brewing and when I need a fill I just trade it for a full one - no worries. Ya never know what pure going to get (steel, aluminum) unless you ask but for brewing it doesn't matter.
That said. If I ask them to fill MY tank they always check the date and will charge me to cert it if need be.
jkosten
I always exchange my tank at the local gas supply. Just ask for a beverage tank and it will be an aluminum tank with a plastic lift handle to make it easier to move around.
sent from my pocket...
