cold weather resin cureing
Itsavanman
so I am in the market for a curing lamp so I can complete the camper project on my jeep this winter. I found this lamp through one of my suppliers at my work for a decent cost.
http://infratech-usa.com/automotive/products/medium-wave-systems/model-sru-1615-ht/
anyone use one of these things in cold weather? its application range is 3 x 4' for paint curing at high temp but i figure it should raise the temp of my 6 x 4' top to above 50 degrees when the ambient temp in the shop will be about 20-30 degrees..
its a 1500w unit, and i have found a few calculators that will calculate how long it will take that unit to raise the air temp completely in the shop, but none to calculate the temp rise of just a work piece. anyone have any input on how to calculate if this heat lamp will work for what i want it to do?
IdaSHO
IDACAMPER
If you are using epoxy, you will be much better off just using a lower temp epoxy system.
As for paint, what paint are you using?
Ive had excellent results with oil based paints curing in low temps by using a fast flashing thinner like Naptha.
Itsavanman
I pulled the trigger on the curing lamp, I'll be using evercoat nonwaxed poly, the footprint of this thing is 2x3 so going to be glassing in 2x3 sections...
