Conqueror Base Camp
Taildragon
Hello everyone,
Time to sell my base camp. Excellent condition with all original equipment. EUK trailer light plug changed to standard US 7 pin round. Arkansas title in hand. I am willing to travel up to 500 miles for gas expense to assist with delivery. The reason Im selling, we have decided to purchase an enclosed trailer.
Also included are 3 toyota landcruiser 80 series wheels off a 1997, that are in descent shape, they could use a refinishing that fit great on the base camp.
No fridge.
Also below are specs from mfg:
Body
Exterior dimensions : 12 ft long, 6 ft wide, 6 ft high.
Standard trailer box with lid and nose cone
Frame
Heavy duty welded steel
Suspension
7 Blade Leaf springs, Heavy duty Shock Absorbers.
Axle
Solid beam axles with drum brakes.
Braking System
Trailco Sigma auto reverse coupler with surge brakes.
Coupling
Sigma hydraulic overrun coupling with hand brake for parking. A standard 2" square receiver for the towing vehicle.
Access
Lid tilts up for access to main compartment. Three lockable doors (2 side and 1 rear) fitted with heavy-duty hinges. 4 wolf pack boxes in the interior.
Paint
All joints sealed with automotive body sealant. Acrylic stone chip primer. 4 coats of white Acryline automotive paint finish.
Roof Rack and Ladder
Opens to 8 x 8 ft. Closes to 4 x 8 ft x 10 inches for closed tent, storage in between, with loading rack on the top. Heavy-duty steel ladder to access tent.
Roof Rack Tent
Heavy-duty canvas tent with 4 side openings with dual zippers, windows and bug screens on 4 sides. 8 x 8 x 6.5 foot high.
Side Tent
Add-a-room side tent fitted underneath open roof rack, approximately 6 x 8 foot floor area. Heavy-duty canvas.
Foam Insulated Saddle boxes
Ridgidized aluminum cases with neoprene seals for water and dust resistance. One is fitted for Minibar, the second fitted with Power Pack.
Storage Includes four dry storage bins.
Minibar
Setup in Saddle Box with compartments for 8 bottles.
Kitchen Unit
Two ridgidized aluminum cases with neoprene seals for water and dust resistance fitted on end of trailer. Two fold out aluminum kitchen tables connecting open cases to form kitchen table of 1.5 ft x 8 ft.
Cutlery & crockery
Service for 6 includes melamine platters, bowls, mugs and kitchen utensils; glasses, full set of cutlery and steak knives. Individual compartments for all items in kitchen unit.
Cooking pots
Set of 3 nested heavy-duty stainless steel cooking pots.
Refrigerator Mounting
Sliding rail system for refrigerator cooler mounted inside on the floor of the trailer and accessible through the rear tailgate.
Power Pack
Industrial Intelligent Power Pack installed in saddle box. 20 amps, 13.8 volts. 5 circuit breakers and GFI. 110 volts AC adaptor coverts 110 volts to 12 volts to power fridge, lights, outlets or charge the battery. Meter shows the battery storage level. A heavy duty, 65 foot, extension cord to connect trailer to a 110 volt outlet or to a portable generator.
Lighting Package
Two Hella halogen spotlights; 1 mounted on front and 1 on rear of roof rack. 2 fluorescent lamps; 1 mounted inside the trailer, the other has 10 foot cord. 3 Hella Plugs; 1 on front and 1 on rear of trailer lid, 1 inside trailer.
Water Tanks
Two 20 gallon Polyethylene tanks for water mounted underneath trailer with risers and bottom mounted taps.
Shower Hose & Water Pump
15 foot hose with water pump to insert in water tank, and quick disconnect fitting on other end for shower head or spray nozzle.
Propane Tank Holders
Two holders for mounting 10 Lb Propane Tanks to side of Trailer
Jerry Cans
Two 20 liter metal Jerry cans for water or gas. Military green
Jerry Can Holders
Two holders for mounting Jerry Cans on side of trailer.
Utility Table
Metal, 2.5 x 6 feet, and mounting for under roof rack
Nose Wheel
Anti tilt leg and removable Jockey wheel, struts to assist in opening and closing lid. Wheel arch rubbers.
7500
call me 314-496-6756
Justin from Bentonville Arkansas
BroncoHauler
Those pics should help you sell this very quickly. If I were ready to buy, I'd be calling you up.
Good luck with the sale.
Herb
Taildragon
Unfortunately, it really all one in the same. I had never thought about detaching the tent, I suppose it's possible. However I couldn't lower the price due to the fact the tent would be unusable without the trailer.
If you YouTube conqueror base camp two good videos pop up showing how this trailer works.
Justin
Dendy Jarrett
Expedition Portal Admin
Staff member
Trailer and tent are really integrated. The roof rack folds in half and the unfolded floor of the rack becomes the tent floor. See a demo video done by one of our members here:
Part 1:
http://www.youtube.com/watch?v=zwRJ21aS-7Q&feature=results_video&playnext=1&list=PLC2C6985E337D3C37
Part 2:
http://www.youtube.com/watch?v=-KpQOvdDeV0&feature=results_video&playnext=1&list=PL97B61D7B41B4E2E0
Hopes that helps. Special trailer- no longer available in the US- I believe there were only 22 Base Camps ever sold in the States.
D
zonker
Thanks for the education! I thought it was like other trailers in regards to the tent. Since I don't need a tent... I will save the sale for someone else.
iStan814
