Conqueror Owners info on the electric panel from the manufacture
Honu
lost on the mainland
OK got a email back from the person that actually makes the electrical panels
I asked him if he had a manual and to explain the isolator switch and any other helpful info he has on the panel we could use :)
this kinda answered the questions about my fans dying ! :)
this is what he said:
to answer all your questions, the battery isolator circuit breaker cut the battery power from the panel. If the isolator is switched off then there are no battery power on the panel, only 12V power from the charger itself. You can leave the power on to charge the batteries, because we use a dedicated battery charging Ic to charge the battery and it go in a trickle charge state with reduduced voltage not to overcharge the batteries.
The fans cycle life is aprox 4-5 years and then they should be renewed.
I hope this will help you.
Dendy Jarrett
Expedition Portal Admin
Staff member
Wow, that is a pretty good amount of info.
I had real issues with my panel this weekend. The battery drained totally and even with a generator connected as shore power, ... with the battery (new) totally drained, I got no power to anything! It sucked!
Luckily I had the generator, so I just hooked the Engel directly to the Honda and let it roll.
D
Dendy Jarrett
Staff member
Contrary, I have a friend (Chris- DieselandMud) who has a Base Camp. He disconnects everything when he is at home (rather than leave hooked to shore power to charge battery) and leaves the battery disconnected to the trailer, but hooked to a Battery Tender to keep it charged. He also used a Diehard Platinum Marine Battery. He had charge left over when he left for the weekend!
D
Honu
no worries on the efforts :)
its fun to find out things :) especially after my smoke filed nose box weekend :) hehehehehehe
I do think I am going to strip it out put in my own Boat/RV stuff and know whats in it ? and might do the same with the axles so I know I can get parts bearings etc.. still love the thing and for me its about the best thing out their :)
flipstick
