Conquorer Base Camp $5,000.00*** SOLD***
dws1057
Sold. Thanks Justin.
Time to sell my base camp. Excellent condition with all original equipment. EUK trailer light plug changed to standard US 7 pin round. Illinois title. Posted is 1 image. I have high resolution images from all angles I can supply to prospective buyer. I am willing to travel up to 500 miles for gas expense to assist with delivery. Primary reason for selling is simply too much for my needs. Typically only two of us camping and often just myself. Price is firm. I will try to check for responses daily but you may also e-mail me at: danshanks@msn.com
My image did not work so I've posted album on photobucket at: http://s1228.photobucket.com/albums/ee460/dws102257/
Also below are specs from mfg:
Body
Exterior dimensions : 12 ft long, 6 ft wide, 6 ft high.
Standard trailer box with lid and nose cone
Frame
Heavy duty welded steel
Suspension
7 Blade Leaf springs, Heavy duty Shock Absorbers.
Axle
Solid beam axles with drum brakes.
Braking System
Trailco Sigma auto reverse coupler with surge brakes.
Coupling
Sigma hydraulic overrun coupling with hand brake for parking. A standard 2" square receiver for the towing vehicle.
Access
Lid tilts up for access to main compartment. Three lockable doors (2 side and 1 rear) fitted with heavy-duty hinges. 4 wolf pack boxes in the interior.
Paint
All joints sealed with automotive body sealant. Acrylic stone chip primer. 4 coats of white Acryline automotive paint finish.
Roof Rack and Ladder
Opens to 8 x 8 ft. Closes to 4 x 8 ft x 10 inches for closed tent, storage in between, with loading rack on the top. Heavy-duty steel ladder to access tent.
Roof Rack Tent
Heavy-duty canvas tent with 4 side openings with dual zippers, windows and bug screens on 4 sides. 8 x 8 x 6.5 foot high.
Side Tent
Add-a-room side tent fitted underneath open roof rack, approximately 6 x 8 foot floor area. Heavy-duty canvas.
Foam Insulated Saddle boxes
Ridgidized aluminum cases with neoprene seals for water and dust resistance. One is fitted for Minibar, the second fitted with Power Pack.
Storage Includes four dry storage bins.
Minibar
Setup in Saddle Box with compartments for 8 bottles.
Kitchen Unit
Two ridgidized aluminum cases with neoprene seals for water and dust resistance fitted on end of trailer. Two fold out aluminum kitchen tables connecting open cases to form kitchen table of 1.5 ft x 8 ft.
Cutlery & crockery
Service for 6 includes melamine platters, bowls, mugs and kitchen utensils; glasses, full set of cutlery and steak knives. Individual compartments for all items in kitchen unit.
Cooking pots
Set of 3 nested heavy-duty stainless steel cooking pots.
Refrigerator Mounting
Sliding rail system for refrigerator cooler mounted inside on the floor of the trailer and accessible through the rear tailgate.
Power Pack
Industrial Intelligent Power Pack installed in saddle box. 20 amps, 13.8 volts. 5 circuit breakers and GFI. 110 volts AC adaptor coverts 110 volts to 12 volts to power fridge, lights, outlets or charge the battery. Meter shows the battery storage level. A heavy duty, 65 foot, extension cord to connect trailer to a 110 volt outlet or to a portable generator.
Lighting Package
Two Hella halogen spotlights; 1 mounted on front and 1 on rear of roof rack. 2 fluorescent lamps; 1 mounted inside the trailer, the other has 10 foot cord. 3 Hella Plugs; 1 on front and 1 on rear of trailer lid, 1 inside trailer.
Water Tanks
Two 20 gallon Polyethylene tanks for water mounted underneath trailer with risers and bottom mounted taps.
Shower Hose & Water Pump
15 foot hose with water pump to insert in water tank, and quick disconnect fitting on other end for shower head or spray nozzle.
Propane Tank Holders
Two holders for mounting 10 Lb Propane Tanks to side of Trailer
Jerry Cans
Two 20 liter metal Jerry cans for water or gas. Military green
Jerry Can Holders
Two holders for mounting Jerry Cans on side of trailer.
Utility Table
Metal, 2.5 x 6 feet, and mounting for under roof rack
Nose Wheel
Anti tilt leg and removable Jockey wheel, struts to assist in opening and closing lid. Wheel arch rubbers.
Herb colvert
