carcrafter22
Hello everyone, this is my first post on expedition portal and I'm new to the whole expedition thing. I have always enjoyed camping and anything outdoors and spend most of my time there but traveling for weeks at a time is something I have never done (except in the military while in Iraq lol).
The family and I have been discussing our big trip and have finally decided to go from our home here in Burleson,Tx to Alaska stopping at a few places along the way.
For the past few months I have been building our camping/ expo rig, its a 2001 jeep grand cherokee. The grand originally started as a 2wd 6 cylinder gas engine with auto trans shortly after buying it we yanked the jeep drivetrain and installed a nissan fd35t diesel engine, after finding it needed a rebuild we just desided to swap in the engine I really wanted anyway.Currently we are almost finished installing the new 3.9L isuzu 4bd1t diesel engine with a GM 4l85e auto trans and b/w 4401 transfer case. The diesel engine is from another project vehicle and has been modded to make well over 300hp (pump turned up capable of over 400hp) so getting around isnt a problem and with the 1 ton drivetrain reliablility should definately be there.
Pics of the jeep with the nissan diesel we installed originally.
Here is the new isuzu going in after making new motor mounts and such.
Here is the jeep, it is pretty basic besides the medium duty series diesel engine and hd trans and transfer case. I instlled some rough country 4" lift springs and shocks along with a clayton long arm kit just in case we go off road.
Sorry for the long intro just wanted to let you know what I'm working with.
I've been reading and reading alot on this forum and cant get enough. I've looked at lots of different trailer designs and ideas, I like the idea of getting a military trailer but at a cost of roughly $500-$700 plus hundreds more in mods I cant see going that route. I considered making a trailer from scratch and its still a close third since I can make it my way, then I came across a thread where an ausi fella cut the back half off of a grand cherokee and turned it into a trailer. I love the idea of making the back half of a grand into a sleeper/trailer, it is certainly different would match my jeep and I can get a complete body with doors and glass for around $350-$500. If you figure the price of the body that is already sealed and complete, add in the cost of some .120 wall 2"X3" steel tube to make the tonge and the price of a sheet of diamond plate to seal in the front section (I'd cut off the body from just in front of the rear doors instead of using the whole body) I can do it for cheaper or at least the same price and have a matching trailer with some style.
Plan would be to remove the front 2 doors then cut the floor and roof about 1ft in front of the rear doors then box it all in and maybe cover the front with diamond plate aluminum of course making it look nice along the way.
I figure it this way
$400 body
$175 in steel and aluminum, I already have steel to make the frame up front, can get the sheet of diamond plate for cheap locally, and have a hitch I can use, 2x3 box steel is cheap as well.
$0 axle and coil spring suspension from my 01 grand will work fine
$150 for a set of factory 16" wheels giving me 2 on the ground and 1 spare
$300 for some used or cheap new 32" tires to match the ones on my jeep now.
Thats $1025 for a very basic trailer that will roll and have tail lights not to mention should be completely sealed from the elements. From there I can add interior lighting, shelves batteries, fuel storage, water storage, etc just like any other trailer.
Does this sound stupid? should I just build a standard ole box type trailer? We would really like some place to just pull over and lay down in, I've even been thinking of installing a small a/c setup for it. We'd be carrying a good bit of stuff so a small trailer isnt going to cut it.
I just wonder if this is a bad idea since I see almost noone do this, most go with the military trailers.
Sorry for the long post and thanks for the help.
Randy
$400 body
Randy
