College Kid
OK, So I am hoping against hope that this is isn't what I think it is.
I spent the weekend fixing up a couple of things on the Disco.
- Bypassed the throttle body heater plate after I broke off a screw (I am planing of fixing this again in the fall once I can track down a used throttle body)
-tighten down the valve covers to hopefully keep the oil leak from happening.
After doing all this, I spent some much needed time under the truck trying to clean away the oil and coolant that had accumulated on the axle and on every part of the under carriage.
Fast forward to tonight, where I spent some time spraying foaming engine cleaner through out the engine bay. I then sprayed down the engine bay at a local spray and wash.
Drove the truck back home and i now have a bad coolant leak!!!!!!!!
it is coming out from behind the engine block,
Any thoughts on what it might be or I could check before I assume it is the head gasket????
