Cost of Camburg 2.5" rebuild, springs included...
Kodachrome
Hi, I did a search on this but since it includes the springs, I came up short, nothing on Camburg's site either...
I am looking to either rebuild or replace my front 2.5” Camburg coil over shocks, they have close to 90K on them, 60K with a 1,000 pounds of camper and gear ( ATC Bobcat ) on the back permanently. They are not leaking at all or behaving odd, but the springs have lost a bit of resistance as the front has dropped a bit, getting some tire rub. I don't have very much pre-load dialed in, maybe an 1.25 inch at most. I have considered cranking them up but with the milage the way they it is and the fact that the camper is staying on, I figure why not rebuild them now before something happens at a bad time.
I live in Colorado in a small ski town, so I can not really do this my self as I simply have no where to do it so I am probably going to have an off road shop do it. I am wondering what the cost of the rebuild kits are and what the possible cost of the new springs might be and if I should up the capacity of the springs to match a permanent 1,000 pound weight gain. This article says the springs average $100 a pop, so that is a start:
http://www.fourwheeler.com/how-to/suspension-brakes/131-0608-coilover-shocks/
Also, is there a way to ball-park the weight on each front corner without driving to a Cat Scale? 150 miles each way in my case.
ebg18t
I would guess the cost would be similar to mine. I just sent my Fox's in for a rebuilt, $80 a shock + shipping.
cam-shaft
Bluebird days
I personally wouldn't waste time with having a local shop rebuild them. Unless Camburg has someone they recommend, I would just send them back to Camburg, they know set-ups very well.
Cam-shaft.
Kodachrome
Yeah, I don't have that option, I have heard they take weeks, can't have the vehicle down that long and no where to do it really.
surlydiesel
In your situation, I would call them up, see if they will send you rebuilds already setup for your weight ect... and you can send yours back when you swap in the new ones as "cores". I think otherwise, you might as well buy a whole new setup and sell the old ones "as is" and recoup what you can. You said they aren't blown yet but the springs have lost some height. Prob work fine for someone just starting out with their first coilovers. When you don't have a spare vehicle or a place to store a car that is suspension-less for a few weeks means you work with what you've got.
-jorge
justinh
If you simply need to swap springs it's about a 2 hour job. You just loosen the tension up enough to remove the lower seat and then swap springs. Piece of cake.
